Another thing to keep in mind is that unless you're setting this up in an anechoic chamber, or at least a room 99% covered in drapes and carpet, you're not going to notice a huge beamforming effect. The reflections from hard surfaces, particularly walls, floor, ceiling, ... will fill in the sound. Add to that the ear's logarithmic response and, it's actually quite difficult to hear a difference between supposed peaks and nulls in the acoustic field.
To get a feel for this you could set up two speakers playing the same sinusoid in phase, then walk a line broadside to them. Can you hear the interference peaks and nulls predicted by theory? If not, you won't be hearing them in your more complex setup either.
