Author Topic: audio related  (Read 3250 times)
Offline angelothewolfTopic starter
audio related
« on: March 19, 2013, 03:20:09 am »
hi everybody, im here to talk, or to hear actually about a transducer: the tapehead
I need a material to put an audio signal with this transducer ( other than tape, of course)  |O
any ideas???   :-DD
Offline c4757p
  • adieu
Re: audio related
« Reply #1 on: March 19, 2013, 03:51:42 am »
Huh?
Offline Psi
Re: audio related
« Reply #2 on: March 19, 2013, 04:14:53 am »
There was a documentary on youtube that someone posted a while back.
They made some magnetic tape on camera and recorded speech on it.
Anyone remember it?
Re: audio related
« Reply #3 on: March 19, 2013, 04:11:48 pm »
magnetic toner fused to a paper tape works, just like old iron oxide tapes. Or use a second one to act as a coupling coil to it, used in the in car audio input units you find all over.
Offline G7PSK
  • It is hot until proved not.
Re: audio related
« Reply #4 on: March 19, 2013, 04:20:50 pm »
Wire or steel ribbon or steel disc any magnetic material can be recorded on it really is just down to what works best.
Re: audio related
« Reply #5 on: March 20, 2013, 01:20:22 am »
interesting...
Re: audio related
« Reply #6 on: March 20, 2013, 01:30:06 am »
yep, im thinking in the wire metod like the old binson delays, but its quite a bit dificult to recreate. im not sure on what aspect of the magnetized material depends the fidelity of the recording??
about the Binson....
http://www.effectrode.com/binson-echorec-memory-system/
