Thank you. That's actually what I had before. I ran it almost as coax, but with ground on one of the inner conductors and on the shield.
I was told this isn't the best option, but I said it worked for me.
Also, I have some pretty long wire runs in the amp. It comes from RCA to a DP4T switch which can toggle between sending the signal to the power amplifiers OR to an headphone amplifier. Headphone amp isn't an issue.
But, now in regard to running wire from this switch to the power amplifier boards, before I had kind of daisy chain. Essentially, I ran the L + R channel signal wires to the subwoofer board (which combines both L + R into one signal), and then off of the input of that same board, I sent two runs to the L + R channel. (Does that make sense??) This makes it a little cleaner and uses less wire. Instead of running 3 separate cables from the switch, I send one, and then split it off at the input of the sub board to the L + R channels. (Sorry if that's unclear).
However, again, I've heard that this daisy chaining approach is somehow bad. I'm not sure exactly why that might be. Any ideas?
Thanks so much.
