Author Topic: Average current mode PFC controller  (Read 1215 times)
Offline ocsetTopic starter
« on: November 28, 2017, 07:50:33 pm »
Hello,
Why do they call “Average Current Mode PFC controllers”,   “Continuous current mode PFC controllers”?   :-//
After all, they may well operate totally in Discontinuous mode.  :D
Eg the following NCP1653  is  “incorrectly” called a “continuous mode pfc controller”
http://www.onsemi.com/pub/Collateral/NCP1653-D.PDF
 8)
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Average current mode PFC controller
« Reply #1 on: November 28, 2017, 08:03:39 pm »
"Average" refers to filtering the inductor current waveform so that the control behaves as a linear circuit without switching (or subtracting the triangle waveform from the baseline, to the same end).
Average mode control allows smaller ripple fractions and greater current limit accuracy than slope compensated peak current mode does.  This makes it particularly useful for low ripple applications, where you might save significant cost on the inductor by using a shitty powdered iron type.
This works whether current is continuous or not, because several cycles are averaged over.
Seven Transistor Labs, LLC
The following users thanked this post: ocset
