We have all year to prepare and I know rope is easy (as we did that this last time) but we really want electronic, no matter the effort required. I think I will look into the RC plane stuff, I may even have a servo from an old nitro RC plane to experiment with. However, it must be installed the night before and all taken down the next day. There are no bars, just the trusses for the roof, HVAC lighting etc, nothing that goes up and down. But now that you mention it, there is no reason we cannot install such a system. Another option to consider! Thanks!
I was also thinking I could replace the resistor in my melting fishing line melter with nichrome wire, so if the person pressing the button holds it too long, there isn't a carbon resistor bursting into flame. I could even encase these nichrome cutters in tiny glass tubes so the hot wire cannot touch anything else (i have a lot of tiny test tubes 6mm*60mm or so). I could even do a mosfet on each one with a 40awg wire holding the gate up, and once it releases, it also tears that gate wire turning off the mosfet and turning off the heating element. I only need about 16 of these devices if dropping from the center of the net.
