Author Topic: basic soldering  (Read 3765 times)
Offline hpibmxTopic starter
  • Country: my
basic soldering
« on: December 06, 2021, 01:26:45 am »
I've been trying to solder however some metals don't really accept the solder they just flow instead of attaching.
1 solution found was to scratch a bit of surface and somehow get attach.
may I know which solder I should use to make this easy?
I've got 63/37 and 60/40 as well. not worked without scratching the surface!
mostly I need to solder on battery plates like (18560) and iPhones battery.
Thank you.
Offline xrunner
  • hp>Agilent>Keysight>???
Re: basic soldering
« Reply #1 on: December 06, 2021, 01:33:20 am »
You probably need to add more flux (and perhaps a higher temperature). What temperature is your iron set to?
Get some extra flux which is widely available - either liquid or paste.
Offline ataradov
    • Personal site
Re: basic soldering
« Reply #2 on: December 06, 2021, 04:14:05 am »
Scratch the plating. The batteries are not typically solderable, they are designed for spot welding. Aggressive active flux might help as well.
Alex
Offline Hiemal
Re: basic soldering
« Reply #3 on: December 06, 2021, 05:04:27 am »
18650 cells are usually solderable, you just have to use a good amount of heat. Just be careful and don't overheat the cell.
Lipo cell tabs are generally NOT solderable. They seem to be either aluminum or some sort of stainless steel alloy that doesn't take to solder, no matter how much flux or heat is used. That's why they're typically spot welded onto something that IS solderable like a Nickle strip or something similar. Another different alternative is to use a bolt/nut combo to clamp down on the tabs and then solder onto that instead.
  • Country: my
Re: basic soldering
« Reply #4 on: December 06, 2021, 08:18:28 am »
I’ll give it try it’s usually set 350 degree or less.
  • Country: my
Re: basic soldering
« Reply #5 on: December 06, 2021, 08:21:10 am »
Thanks I’ll try another flex too
  • Country: my
Re: basic soldering
« Reply #6 on: December 06, 2021, 08:27:31 am »
Agreed. 18650 seem to be solderable just need to add up my heat as I was cautious about that.
I found out about supper capacitors which is rated low voltage and high capacity. 2.7v 500f this would help me do spot welding. Of course I need to be extra cautious with that.
https://www.amazon.com/Capacitor-Suitable-Automotive-Rectifiers-Condenser/dp/B082FX71GR/ref=mp_s_a_1_4?keywords=supercapacitors&qid=1638779132&sr=8-4
Online tooki
Re: basic soldering
« Reply #7 on: December 06, 2021, 08:50:13 am »
Soldering to batteries is not recommended. If you absolutely must do it, make sure you use a big soldering iron tip, set hot, so that you can get the joint made fast. The last thing you want is for it to take 20 seconds to make the joint.
  • Country: my
Re: basic soldering
« Reply #8 on: December 06, 2021, 02:48:32 pm »
Yes I really have to do it yes. Thank you for your advice.
Offline David Hess
  • DavidH
Re: basic soldering
« Reply #9 on: December 06, 2021, 08:09:40 pm »
The best results I have gotten were by using an emery wheel or tip to clean the surface.
The following users thanked this post: hpibmx
  • Country: my
Re: basic soldering
« Reply #10 on: December 12, 2021, 03:46:01 am »
I agree that's the best result.
Offline CarlosGarcia
  • Country: ar
Re: basic soldering
« Reply #11 on: March 03, 2022, 04:22:56 pm »
use a little bit of phosphoric acid
