What's the point in saving 1 minute of thought put into using the right tool for the job, whether it be a FET, a relay or a solid state relay and doing the polarity right? You only have to design it once.
Guess you're thinking mostly of solid state relays which can switch both AC and DC, just go to digikey and search for solid state relays with output type AC, DC.
