This is reference to my earlier post:
https://www.eevblog.com/forum/projects/weird-coil-configuration-does-it-classify-as-parallel-lc-circuit/Please refer to this post and specifically Reply #24 for more information about the exact set up. I am looking to measure the current on either the input or output as accurately as possible without buying a super expensive current probe or wasting a lot of power. If having to choose, I would rather do the latter.
The current probe I currently have is MicSig CP503B, which to my understanding can measure only 20 mA reliably. Again, I am working in kHz to low MHz range. Budget is, of course, limited.
I am using a signal generator to drive my circuit. Now I know impedance matching is a significant issue here as well so looking for suggestions or to know if it's even possible (and how to do it, precisely). I was thinking of using a precise resistor in series and measure the voltage drop across it but again there is the impedance matching issue.
Any suggestions? Please give as much detail as is possible.
