Author Topic: BlackBox: binary, lightweight communication protocol handler code generator.  (Read 1548 times)
Offline cheblinTopic starter
  • Country: cn
Hello!
Recently I finished the BlackBox: binary, lightweight communication protocol handler code generator.
And now complete new project which converting of MAVLink protocol description XML file into the BlackBox format
It is clearly demonstrates the maturity of BlackBox and its comparatively greater capability against MAVLink.
Everything works just fine, all tests are passed successfully. Therefore I decided to share this with you, guys.
What are the advantages?
  • The BlackBox format of the protocol and the network topology description file is presented as plain java source - more compact and familiar for the programmers, instead of XML format in the MAVLink.
    Plain java file format supported by many development environments with all the refactoring capabilities.
additional data formats:
  • fields with the built-in structure of multidimensional arrays;
  • fields of sparse multidimensional arrays;
  • bit fields;
  • fields with the built-in structure of multidimensional arrays of bits;
Using BlackBox , you can easily establish communication not only between microcontrollers, mobile devices but also between the ordinary computers. And what is important, without time and effort waste. In fact, the generated BlackBox code can become the skeleton of your distributed application. The programmer will just have to add handlers to the packet's reception events, as well as the logic for creating the package, populating it with data and sending it to the recipient.
BlackBox generates the source code in the following programming languages: JAVA, C#, C.
Forget about:
 MQTT
 MQTT-SN
 CoAP
 SMCP
 STOMP
 XMPP
 XMPP-IoT
 Mihini/M3DA
 AMQP
 DDS
 LLAP
 LWM2M
 SSI
With BlackBox you can build you own protocol, fit to only your project needs. You will get very efficient, fast, working over USART or TCP/IP protocol.
Here is an example of demo project to control from Android based mobile, blinking LED on a board under STM8S103F3P6 via Bluetooth UART on HC 08.
« Last Edit: February 17, 2018, 05:01:01 pm by cheblin »
Offline Leo Bodnar
Thanks for the list of references.  I can never remember MQTT acronym when I need it.
Forget about:
 MQTT
 MQTT-SN
 CoAP
 SMCP
 STOMP
 XMPP
 XMPP-IoT
 Mihini/M3DA
 AMQP
 DDS
 LLAP
 LWM2M
 SSI
