Did you connect the GND pin? Did you set the correct baud rate?
Since the whole motherboard has common GND, USB and serial port's 5 pin is common GND and hence wasn't possible to externally connect them. Also, The site asked to mention less than 115200 bauds while I was much lower at 9600. Can you help me, with what Those square BOXES in output denote?..
