Author Topic: Bluetooth device  (Read 2991 times)
Offline LatvianOnJuiceTopic starter
Bluetooth device
« on: January 19, 2015, 11:12:30 pm »
Hello, everyone!
I decided that I would love to do a project, which includes controlling a home appliance via bluetooth. I am still searching about these kind of projects as I am typing this post, but I wanted to ask you guys, if anyone has done anything that is related to controlling via bluetooth. Ideally, I would love to, for example, turn on an LED by using a self-programmed app on my phone.
This is my first time doing anything related to this, so I will really appreciate any kind of webpages, sources, or any information that you would be kind enough to share.
Thank you in advance!
Cheers!
Offline paulie
Re: Bluetooth device
« Reply #1 on: January 19, 2015, 11:31:26 pm »
By far the easiest approach is to program a PIC or AVR to read inputs from a cheap HC05 or HC06 bluetooth module and control the LED or other external devices. The bluetooth  module itself does have I/O and can be programed but not as easy. On the other end one of those $1 bluetooth dongles plugged into a PC or Android phone by itself running Blueterm make a great control console. Simple serial protocols make this a cinch. Google is your friend.
Offline Richard Crowley
  • KJ7YLK
« Reply #2 on: January 19, 2015, 11:34:56 pm »
There are several Bluetooth interface boards ("shields") for Arduino that do exactly that.
They let you control things (via the Arduino) from an IOS or Android app.
This is just the first hit on Google: http://www.makershed.com/products/bluetooth-low-energy-ble-shield-for-arduino-2-0
designed to let you interface your Arduino with compatible iOS or Android devices without wires or jail-breaking. It works with all Arduino boards, including Arduino Uno, Mega 2560, Leonardo, and Due.
Offline diegosfb
  • Country: ar
« Reply #3 on: January 19, 2015, 11:45:39 pm »
Its really not very hard, those bluetooth modules they are talking about, they just work receiving/transmiting serial commands.
You can even test them with a PC instead of a microcontroller (sounds like you know how to program it might be easier to test the modules using a terminal and a max232 board for level conversion if needed (depends on the module used).
I have made a Bluetooth RS-232 wireless connection and works like a charm, with that you can control tons of bluetooth devices
The only concer will be range, keep in mind the range is limited, and it probably wont cover your hole house
Good luck
« Reply #4 on: January 20, 2015, 12:06:36 am »
Thank you guys for the input! I am still googling and taking notes on pretty much everything I find... This is just a personal future project I would like to do. No rush, no particular desire regarding the end result, however, I want to find & learn everything I can about this, since it seems very intriguing to me!
