Author Topic: BMS for 10S lithium pack  (Read 1262 times)
Offline PanSam1986Topic starter
« on: October 01, 2022, 10:29:44 pm »
Hi all,
I am having trouble finding a BMS for a 10s pack I want to build with a max 5A rating or less. I have 21700 unprotected cells for this project. I was contemplating using 10 1s bms boards + balancing board but I’m not really sure if that would work. The only other solution I can think of is getting a 15A rated 10s bms and connecting a 5A PTC fuse in between. I have never built a lithium pack before so any help would be greatly appreciated.
Online NiHaoMike
    • Facebook Page
Re: BMS for 10S lithium pack
« Reply #1 on: October 01, 2022, 11:25:26 pm »
Replace the current sense resistor with one of 3x the resistance.
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
Offline tekguy
« Reply #2 on: October 02, 2022, 08:45:32 am »
dont use an mot transfo type tab welder,i made one with a ssr switched primary and a dual pulse timer,it just cooked the cells never welded the nickel,then got a cheap chinese car battery powered welder,that had the fets short on first use ,did the mods as in this vid,now works great from a 30ah car battery. i got this one
« Reply #3 on: October 02, 2022, 10:54:11 am »
@NiHaoMike Thanks, makes sense.
@tekguy I actually purchased 21700 cells with pre-installed copper tabs just so that I wouldn’t have to do it myself.
