So it's all fine until it isn't, and then you're stuck having to implement the full solution anyway. Same as all the built in "bode" plot tools from other manufacturers.
It is full solution. It is more comprehensive than any out there at this moment. It has one annoyance, and that is that you cannot make it less selective and less resilient to errors if you want to run it faster. Which would be nice for some occasions. I agree. I did ask Siglent to think about adding that option.
Wow put your marketing hat away with those forcefully directed claims. You can keep blowing up with more positive energy and brand fanboyism but its not addressing the limitations.
Yes, it is complete or "full". But.....
It is not more comprehensive than any other option, only if you consider "canned" oscilloscope analysis options.
Yes you cannot make it less selective and faster, but you cannot make it more selective and slower either! It is fixed and may not match the users needs, and is unlikely to ever be optimal.
I said people would need to put together a "full" solution to go further if they found any single limitation in the built in app, to surpass its basic feature set. It is right there in the quote you chose.
But if you compare it to doing it all manually, or spending time writing and setting up your hand made software solution you are still order(s) of magnitude faster the way it is now.
Keep saying this every time it is brought up, and we'll keep pointing out there are many existing software solutions out there. Not comparable at all to doing it by hand over and over. Skipping over the main point which is:
if the built in app does not have the required feature/option/capability, in this case increasing selectivity for extracting the synchronous signal amongst switching activity/noise, then it is simply no use. A dead end at which point something else is required, as the OP has hit with their example.
I suggest the OP would be better off understanding the underling techniques and methods rather than buying n oscilloscopes so they can swap them out hoping that the particular bode measurement application hits their needs.
But we've been here before:
https://www.eevblog.com/forum/projects/bode-plot-(-1hz-to-10-mhz)/?allSame people, same fanboyism.
