for a project I need to convert 12V to 15V at relatively low output current (10-50mA). Usually my go-to switching controller is the AP3012. Low cost, high frequency.
However as it turns out at such low currents, the AP3012 has far worse ripple as compared to higher currents. The reason seems to be, that the 3012 goes into "pulse skipping" mode, effectively lowering the frequency significantly and thus creating a large output ripple.
I also tested the LT1615 with basically the same results.
Looking for an alternative part designed for lower current I found the LT1615-1, but even before the supply shortage it could not be obtained.
I did have success with LT3460, it is however much too expensive for my application.
AP3015 seems to have a undefined, much lower operation frequency. Have not tested yet
So basically this results in my 2 questions:
(1) Are there alternative parts I could use? Something I am not aware of? Recommendations?
(2) Is it possible to somehow reduce the ripple of the AP3012? I tried altering the feedback network, reducing and increasing the inductance and output cap - all with little to no positive effect.
thank you!
