Author Topic: Bought many LM3914 (VU-meter style 10 LEDs driver), now what to build?!?  (Read 859 times)
Offline RoGeorgeTopic starter
Got a bag of LM3914, NOS from the '90s, made by National Semiconductor.  8)
LM3914 - Dot/Bar Display Driver
The LM3914 is a monolithic integrated circuit that senses
analog voltage levels and drives 10 LEDs, providing a linear
analog display. A single pin changes the display from a mov-
ing dot to a bar graph. Current drive to the LEDs is regulated
and programmable, eliminating the need for resistors. This
feature is one that allows operation of the whole system from
less than 3V.
  • Drives LEDs, LCDs or vacuum fluorescents
  • Bar or dot display mode externally selectable by user
  • Expandable to displays of 100 steps
  • Internal voltage reference from 1.2V to 12V
  • Operates with single supply of less than 3V
  • Inputs operate down to ground
  • Output current programmable from 2 mA to 30 mA
  • No multiplex switching or interaction between outputs
  • Input withstands ± 35V without damage or false outputs
  • LED driver outputs are current regulated, open-collectors
  • Outputs can interface with TTL or CMOS logic
  • The internal 10-step divider is floating and can be referenced to a wide range of voltages
(from LM3914 datasheet, https://www.alldatasheet.com/datasheet-pdf/pdf/8898/NSC/LM3914.html )
It was an impulse buy, don't ask why.  I have no regrets.  ^-^
Looking for interesting applications, any ideas are welcome.
« Last Edit: September 17, 2026, 02:56:29 pm by RoGeorge »
Online ledtester
Re: Bought many LM3914 (VU-meter style 10 LEDs driver), now what to build?!?
« Reply #1 on: September 17, 2026, 03:47:53 pm »
There's always this idea...The PDF contains the fill-page ad for the device.
« Last Edit: September 17, 2026, 03:54:25 pm by ledtester »
« Reply #2 on: September 17, 2026, 04:35:04 pm »
I'm thinking as a first test to make a Li-ion single-cell discharges (to measure the mAh of phone batteries):
    - the idea is to use the constant current in the LM3914 LEDs to make a 20-200mA adjustable constant current load
    - the LEDs will draw their current from the DUT Li-ion battery
    - the mAh can be deduced by counting the total time during which the DUT battery was able to keep the LEDs on
    - a trim-pot could set the number of LEDs always on (so to set the discharging current according to the battery capacity)
    - LM3914 can be powered with as low as 3V, so it might work to self-power the entire circuit from the DUT it discharges  :D
    - the on-chip Vref should be good enough to keep the current constant while discharging from 4.2V to 3V
    - should use red LEDs, for their lower Vf drop, to let some margin for the IC open collector BJTs while the DUT approaches 3V
« Last Edit: September 17, 2026, 04:38:34 pm by RoGeorge »
Online themadhippy
« Reply #3 on: September 17, 2026, 05:35:34 pm »
I used one years ago to make a power up/down sequencer,simple ramp generator to the input and relays on the outputs.
Online Doctorandus_P
« Reply #4 on: September 17, 2026, 05:42:23 pm »
LM3914 is the linear version. For the "VU" meter, you would want the LM3915, which has a logarithmic scale for the resistor string
Oopsie, I forgot about the LM1916, so read on to the next comment.
« Last Edit: September 17, 2026, 09:48:09 pm by Doctorandus_P »
Online themadhippy
« Reply #5 on: September 17, 2026, 07:02:11 pm »
the lm3915 is equal 3db steps ,for proper vu metreage its the lm3916 you wants
The following users thanked this post: Doctorandus_P
Online oPossum
« Reply #6 on: September 17, 2026, 11:32:03 pm »
The following users thanked this post: RoGeorge, UnijunctionTransistor
Offline UnijunctionTransistor
  • Ohms Law: Resistance is futile.
« Reply #7 on: September 17, 2026, 11:35:54 pm »
If you don't find enough projects to consume all of the ICs, you can always sell them.
NOS National Semiconductor LM3914s command attractive prices.
But are you sure that they are legit?
« Last Edit: September 17, 2026, 11:38:39 pm by UnijunctionTransistor »
That should be fun, thanks.  :-+
The date/name stamp suggests you just drawn that, or is it a copy/paste?  I'm interested what editor was used to draw the schematic.
Bought them from a brick and mortar shop, the seller is also the shop owner.  I think those are genuine NOS parts.  Bought them to build funny things, not for reselling.  I don't even have an eBay account.
Online oPossum
Yes, it is my design. Drawn in Eagle 7.
I got some LM3914 clones that I had to test. There are at least three brands of LM3914/15/16 clones. Two are available from LCSC.
https://www.lcsc.com/product-detail/C53199171.html
https://www.lcsc.com/product-detail/C55109573.html
Here is a video showing that circuit and a 555 + 393 quadrature circuit.
Clever those 4 LEDs!  8)
Online oPossum
