Author Topic: bridge rectifier  (Read 2187 times)
Offline [email protected]Topic starter
bridge rectifier
« on: December 07, 2013, 06:16:51 pm »
i am further connecting the output to igbt to control power through the resistor
but the rectifier is behaving in the below shown manner.
even tested it on actual hardware but it gives only alternate half cycles.
pls help
Offline minime72706
Re: bridge rectifier
« Reply #1 on: December 07, 2013, 06:29:23 pm »
Why are you only connected to one side of the bridge rectifier's pulsating DC output? The other is floating. You'd at least need a node attached to it letting the simulator know it is node 0 or ground or whatever.
I have more incomplete projects than I have digits and toes.
« Reply #2 on: December 07, 2013, 06:42:40 pm »
i connected it to ground also
output of proteus is anyways not getting affected
