Author Topic: Buck converter acting up?  (Read 1008 times)
Offline drummerdimitriTopic starter
  • Country: lb
« on: December 11, 2019, 02:15:39 pm »
I have attached a graph of the voltage and how it keep dropping from around 5.3 to 5V DC when not under load.
At 1A load, the behaviour continues but the voltage drop is much less and at higher loads (4A) this is no longer an issue.
Is this normal or is my unit shot? What could be the culprit and how can I fix it?
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Buck converter acting up?
« Reply #1 on: December 11, 2019, 02:28:44 pm »
No idea.  I mean, doesn't sound right.  But what is it?
Seven Transistor Labs, LLC
  • Country: lb
« Reply #2 on: December 11, 2019, 02:37:31 pm »
I've attached the datasheet of the unit in question.
Offline T3sl4co1l
« Reply #3 on: December 11, 2019, 10:56:18 pm »
I don't see any documentation or schematic or support contact or anything, so you'll have to figure out what kind of support the manufacturer provides, if any.
