The long answer:
Minimum duty cycly is one parameter you can check. May not be in all datasheets though. Theoretical minimum is 5/6 = 83,3%, but you'll probably need around 90% duty cycle depending on efficiency.
Some buck converters can run at 100% duty cycle, then you'll be safe. Otherwise you'll probably need a synchronous buck to get high enough efficiency.
The short answer:
Use e.g. LT, AD, TI power design tools to see what fits your design.
