Hello!
Here I have a full-bridge buck-boost converter that I designed. I have done a handful of buck converters but not one this complex, so I figured some feedback would be a good idea.
The converter is based on the Texas Instruments LM51770, most of the circuit design came from TIs online power designer tool.
The input to this converter is DC from a brushed motor running as a generator, the voltage will range between 8 and 25 volts, so I designed for 6 to 30 volts. The generator is only rated for 10 amps, so I put the LM51770's auxiliary current shunt on the input. The output is meant to be a fixed 13.5V for a system based on a 12V lead-acid battery.
I tried to keep this converter as inexpensive as possible without cutting corners on components, this is the reason for the two layer board. I mounted the mosfets on the bottom of the board so that I could bolt it flat to a heatsink.
The biggest differences from the TI power designer are the addition of J4 as well as Q1 and D1. J4 lets me adjust the operating mode slightly, and Q1+D1 is effectively a fault/power good indicator.
Feel free to ask many questions, thanks!
