Regarding output voltage: 20vpp is indeed quite typical, but only in high impedance mode. In 50Ohm mode, most generators reach only 10vpp.
And about PWM mode: be aware that most generators are crippled regarding the duty cycle range. E.g. older model from Agilent support only 20% to 80% duty cycle - even for low frequencies. Some Rigols etc. only support 50% above a certain frequency range. That makes the PWM/DC feature kinda pointless for certain applications.
The next question would be if you need arbitrary mode and/or remote control via Visa/SCPI. Both can be very handy, but ARB mode is very limited on most affordable generators (e.g. 1MPoint would be state of the art, 16k would be acceptable, but everything below that is kinda useless). Also while e.g. Rigol generators support Visa/SCPI, the command set is somewhat crippled if you compare it to an Agilent 33521A (which is the best affordable arbitrary generator anyway).
Last but not least, the question is how much money you want to spend.
