Yes, just replaced PSU capacitors, and while the ones that had vented were of various values capacitance wise, from 22pf up to 300uF, for a 2200uF 10V unit, the ones with some capacitance, just bulged, had ESR in the 0.1r range, and looking at the Chongx ones next to them, all still nominally the rated value, but ESR around 0.5R, they were not long for life.Decided to replace every one over 1000uF in the power supply, using what is available, Nichicon 1800uF 16V, as I needed 10mm diameter ones, and that value is locally stocked, and vaguely has a current rating for ripple near the originals. Not bothered to use lower voltage rating for the 5V and 3V3 rails, the ripple current rating is lower for the parts, so used the 1.9A ones all over. Hopefully they will last better, and while there taking the power supply apart I lubricated the fan as well, sleeve bearing and at least 11 years old, seeing as this is a 2010 made unit. Capacitors 7k hour endurance, hopefully will last better than the Jwelect ones, with the 10k fiction life, they put in originally, Most were bulging, though of those that were not, they all were well cooked, and starting to weep out the base.
