Author Topic: Cable Copulation Prophylaxis Found  (Read 809 times)
Offline rhbTopic starter
« on: January 18, 2025, 10:35:42 pm »
For many years I've used a set of slotted Pomona cable racks.  Inevitably, no matter which cable I wanted it was actively copulating with at least several other cables.  If they reproduced I wouldn't object, but as they do not, I've had enough.  Strict chastity will be rigidly enforced.  Promiscuous copulation will no longer be tolerated.
I scavenged from the trash a couple of old hollow core closet doors which have been sitting waiting for a new purpose in life.  It has been granted.
Basic idea is to screw slit pieces of tubing with very small wood screws to the door to hold the cable.  My first choice was polyethylene.   I found that I had to cut a strip off the tube because forcing RG-58U through a simple slit split the tubing.   This used up the 4 ft of polyethylene, so I'll try vinyl or neoprene next.  Very likely you could staple vinyl tubing to a plaster board wall and not even leave any marks.
The doors will be mounted to the wall or end of the rack (TBD) so that I can select cables from any of the 4 sides.  Ultimately there will be a pair of 6 bay wide racks facing each other with a moveable bench about 5 ft long running between the two racks.
FWIW the racks are DIY 14 gauge 1" x 2" rectangular tubing for the uprights and 1.5"x2"x1/8" steel angle with cable bracing.  Final configuration will have all graphic displays at standing height.  Hence the need for 12 bays in total.  Angle is predrilled and secured by self drilling screws.  No rack HW needed and excellent air flow.  Stick the instrument exactly at the height I want.
Have Fun!
Reg
The following users thanked this post: BILLPOD
Offline inse
Re: Cable Copulation Prophylaxis Found
« Reply #1 on: January 18, 2025, 10:43:25 pm »
Reg, why wouldn‘t you allow your cables to have some fun without consequences in the lab after hours?
No, fun aside - this would be much too tidy for me, I am a confessing untangler.
Even more fun aside: nice solution
« Reply #2 on: January 18, 2025, 10:57:36 pm »
It was the consequences during working hours trying to separate them that made their extracurricular  activities no longer tolerable.  Proper conduct will be maintained.
Fundamental problem is if you don't have a specific place for the profusion of essential cabling you spend a lot of your time trying to untangle things.  The Pomona racks just dump several slots on the floor for you to pick up.
Based on this experiment, I'm going to try stapling clear 3/8" ID vinyl tubing using a light staple gun that shoots office stapler size staples.  Super handy.  I secure computer cables using velcro strips stapled to the wall.  Super easy to access a single cable or reroute for a change.
