On Friday I lost my internet connection abruptly. When I went to check modem (2WIRE ADSL modem) I found dead AC adapter. modem was damaged at phone line input but that is another story.
It was 5V DC, 2A rated adapter made out of two glued plastic shells and PCB inside. I never cared about power supplies - when I need one for project or something else I buy a brick from DigiKey. I cracked my failed adapter open with screwdriver and immediately found busted 100uF/10V electrolytic aluminum capacitor inside. I replaced the capacitor, taped the shells back together and plugged it into socket to test this is when I started finding out strange things about it. Strange only to me of course
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/xgrin.gif.pagespeed.ic.QVVz6XIT20.png)
First of all it suppose to generate 5V DC output and according to specs on the case it is rated to up to 2A. I hooked it up to large 10W, 8 Ohm resistor and I got ~4.54V, when I added another one in parallel I got 4.1V or so. 5V/4ohm = 1.25A, not good, but modem was OK with it I guess. When I looked at it again I found the mystery device at the output of an adapter.
It is a TO-92 package marked as "431-B SI 9G". I did some googling and I found this datasheet
http://www.fairchildsemi.com/ds/TL/TL431A.pdf. I am not entirely sure it is the right datasheet. I de-soldered it and tried to test it, but it is either this device is busted too or I don't understand how it suppose to work. According to a datasheet it emulates a simple zener diode, but in addition to basic zener functionality it allows to control breakdown voltage by applying reference voltage to REF pin.
According to a datasheet I expect reverse breakdown voltage of this "emulated zener" to change when I apply something around 2.495V to a REF pin. What I got instead is that it works as a gate - it breaks down when I apply ~1.8V to REF. Is this happen because
A. I do not understand how it works?
B. It is damaged device?
C. both?
