I have constructed an array of 9 ceramic disks in 3 groups of 3 and on an area of about 100mm x 65mm. I have attached a picture of how they are arranged. The surrounding rectangle is the size of the whole pad around 130mm x 90mm.
The array will be placed on a curved surface, the curvature varying from application to application so the array is semi-flexible.
Currently the 9 disks are held together by silk tape and on top another fixing tape. The glue present on the silk tape holds the disks in place relative to each other. The fixing tape then secures the whole array onto the target surface.
Because the target surface is curved and because the arrays are washed in water after each application, the assembly loses a bit of its shape, but most importantly the glue leaks and the whole thing becomes rigid with glue and not very supple anymore. Therefore after a few use-wash-dry cycles, the assembly must be taken apart, the silk and other tapes discarded, and the ceramic tiles then reused.
I was thinking of providing a better construction using a thin plastic holder/template to glue the ceramic disks permanently onto it, so that they could be washed in water without losing their shape. I could cut the plastic template out of some plastic sheet. I was thinking maybe 1mm thickness, must be flexible but also strong. I attach another picture of what the plastic holder might look like.
So what remains is (a) identification of the correct plastic and (b) cutting it perfectly - cannot imagine trying to cut this template out of a plastic sheet with plain old sciscors.
Any ideas greatly appreciated. I have attached a picture of the proposed plastic holder.
