Hello! I designed a charge amplifier circuit for piezo conditioning. It is an AC circuit with a virtual ground to get the midpoint somewhere between 0-3.3V so the signal fits into the ADC range.
I made this circuit:
I simulated it to get the right frequency response and amplitude and tested it on a bread board. I had to change some values on the breadboard but I had to use the components I had on hand so I can test the amplification level I need.
The problem I'm facing which did not show up in spice is that if I change the value of resistors R3-R5 I change the center point voltage reference. In spice the midpoint voltage is 1.65V no matter what compnents I use.
Why does it not show up in spice and can I change something in spice to show me what the resulting midpoint voltage will be?
As you can see I have 1.65V as a reference and the only difference to my real circuit is that I have an op amp supply the 1.65V virtual ground.
The final circuit I will order as a PCB will look like this:
I can't test it because I don't have the exact components at home.
Can I somehow calculate what the resulting mid point voltage will be on this circuit so I can change the voltage reference point to give me the desired midpoint voltage? Can I change something in spice maybe?
Thanks.
