Last year I bought a Yamaha Electone organ for the princely sum of £20 to rob some attractive lever-type potentiometers from it. That didn't quite go to plan and I ended up keeping it to play and buying another to tear apart later. I just couldn't bring myself to dismantle it when I saw its almost pristine condition, plus being a musician I couldn't resist playing with it and enjoying the bloopy rhythm section and analogue string sounds.
It works pretty well considering its age, although upon first power-up the 250V mains filter cap expressed its displeasure at being dried up by spewing its guts over the PSU board, but that was easily replaced. However when on there is a very noticeable mains hum which the later one (that I took apart) did not exhibit. Unfortunately the second organ was a lesser model with no compatible parts so a simple swap isn't going to work.
I've stripped down the power supply and recapped it, so I'm confident that that's working OK. The hum is independent of the volume control and is present on both amplifier channels (one main speaker, one tremolo speaker). I've been able to make the hum go away by shorting the output op-amp inputs to ground, which suggests that the hum is somewhere in the signal path. My main suspicion at the moment is capacitors. The PCBs basically look as if someone emptied a sack of capacitors onto them so there's plenty of scope for one to go wrong somewhere. Here's a picture of some of the instrument filtering circuitry and to the top left are some dodgy-looking caps. (warning: large image)
http://farm8.staticflickr.com/7144/6482334705_04a6656577_o.jpgThere's a clear blue resin-like buildup with some small bubbles in it on the top of nearly all of that type of cap (Nichicon) throughout the organ and I was wondering if that could be electrolyte. I've desoldered a few and checked their capacity and all seems well, however I don't currently have an ESR meter to check that. They're also present in large quantities on the main board which deals with sound generation, digital logic and the summing and switching of the audio signals prior to returning to the amp outputs. That's where I'm currently guessing the problem may lie...
Also can anyone identify the off-white caps? I believe they're polyester film but not 100% certain and if they're likely to have degraded over 30 years I could end up replacing them if I can't avoid it.
I've given the organ plenty of time to run in and settle down over the past 12 months and the 50Hz hum is still very obvious so it's not going to go away on its own. Any suggestions or advice anyone could offer would be much appreciated!
