Or, does anyone know what 915 MHz technique the $25.00 LaCrosse weather station uses? Its range, data rate, and power usage are perfect for my needs. To figure out which RF chipset they use, I bought one and opened it up... and saw two COB blobs, nothing else. Drat.
Why: I want to scatter some small sensors (temp, pir, beam break) around the house and shop. Every few minutes or hours (any time something interesting happens) they will report their reading to to home base. Each burst of traffic is 4 to 8 bytes: 2 byte ID, 2+ byte reading. Figure I'd use an ATTiny in each sensor, maybe a Raspberry Pi as the base station, pretty much anything would work.
I'm not seeing a good way to implement the RF. BTLE is close but has range issues. Most sub-1-GHz chipsets I've found are relatively expensive ($8+) and have way too much bandwidth. I want less!
TI's CC100 seems closest but still a little expensive for what I want. There's gotta be something like it, but less integrated and cheaper?
Thanks for any hints.
