I see the speed issue with the 3020...it's not going to be a very quick P&P
So, that's out.
I figure I will try and make my own in that case. A plan is forming in my mind...
1. Belt driven, for speed, and low cost. Problem with accuracy though? I don't know...
2. Unsupported rails all round, no large forces to deal with and lower cost than supported rails.
3. Cam driven or belt driven Z-axis? Can't decide...
4. Maybe use extruded aluminium as a frame, not sure on fixings for rails etc though...
5. What motors to use? Belt direct drive so would need to be fairly high torque, simply for overcoming inertia on startup and reverse...
I figure I can get a fairly nice XYZ system for around £230 with this plan, unless there's anything I'm missing...
Thoughts would be appreciated
And I will keep my log mostly here, simply for the fact that this forum seems more active than mycncuk. Oh, and the great minds I know reside here
