Author Topic: Circuit Explanation [ PICS ] [ Q ]  (Read 2401 times)
Offline jMrLTopic starter
  • Cook By Day, Gamer and Tech Enthusiast by Night
    • YoloDigi
« on: August 14, 2017, 09:51:36 am »
Hello,
First off id like to say hi. My name is Jeremy. I've been a DIY tweaker for a little time now. I have started to ravage through all used electronics I can get my hands on just to stock pile my component inventory. I ran across this board and was curious what is the implementation of such. I'm assuming it has something to do with voltage conversion and possible an up/down also.I have done some research on some of the parts and some don't have labels so I'm stuck with the google search atm.
http://www.mouser.com/ProductDetail/ON-Semiconductor/FQPF5N60C/?qs=%2fha2pyFadugJAM1sHG7DOqc7IemPvgRwrlXP8hvmbIw%3d
http://www.alldatasheet.com/datasheet-pdf/pdf/68338/IRF/IRF9952.html
http://www.alldatasheet.com/datasheet-pdf/pdf/257613/WINGS/TL431A.html
Any explanation would be awesome. Also To hook up I would Use the Circled sections for in and out?
Link to Gallery <  http://diy.yolodigi.com/imgs/pcb/  >
Thanks,
Jeremy
Remember You Are Amazing!
Seeking someone that Loves speaking and Loves Tech.
https://yolodigi.com Tech/Gaming Discord
Offline Rerouter
Re: Circuit Explanation [ PICS ] [ Q ]
« Reply #1 on: August 14, 2017, 09:59:45 am »
Looks like a dodgy AC - DC power supply.
http://tri-heros.net/uploads/news/2013_01/untitled_119.png
Offline Paul Rose
« Reply #2 on: August 14, 2017, 07:32:45 pm »
This is a typical switchmode power supply.
The 8 pin chip on is a UC3843 pwm controller
http://www.alldatasheet.com/datasheet-pdf/pdf/25562/STMICROELECTRONICS/UC3843.html
The 4 pin chip beside the yellow transformer is an optocoupler
The in and out labels you drew on the foil side picture are reversed.
Think of the board divided into two isolated regions with the yellow transformer and opto-coupler separating the high voltage/low current side ( larger area with more parts ) from the low voltage/high current side ( smaller area with fewer parts ).
The high voltage side rectifies ( likely mains voltage 50/60 Hz ) AC and chops it up into pulses with the IRF9952 under control of the UC3843.
The high frequency pulses are transformed to a lower voltage/higher current by the transformer.  These low voltage pulses are rectified by the large diode and smoothed by the small electrolytic.  The TL431 monitors this voltage and drives the "send" side of the opto-coupler.  The "receive" side of the opto-coupler is used by the UC3843 to adjust the pulse width of the high voltage pulses.
When the output voltage is too low, the pulses are widened, which in turn raises the output voltage.
When the output voltage is too high, the pulses are narrowed, which in turn lowers the output voltage.
The following users thanked this post: Mukrakiish
Offline VoltJesus
  • All your Volts will be save
« Reply #3 on: August 19, 2017, 05:18:32 pm »
That board looks eerily familiar. Looks like it came out of either a convection oven or range.
I am thinking it is going to be 24v output. Try it with 110-120v input first and see what you get. Some of them do convert 208-220v down, but most I've seen run off 110.
Paul Rose gave a much better explanation of how the circuit actually operates than I could even attempt to give.
Offline floobydust
« Reply #4 on: August 19, 2017, 05:40:41 pm »
The IC datasheet and app notes can tell more about the basic architecture of the circuit. Most of these AC-DC power supplies are copied from the datasheet.
But remember... It is typical cheap stuff from china that has no safety approvals. It has no primary-side fuse, so I don't use these in my home.
Solder balls and flux residue, it's a pretty dirty PCB. I would give it a wash in IPA and toothbrush scrub.
