Author Topic: Circuit idea for high side MOSFET driving  (Read 5563 times)
Offline hkBattousaiTopic starter
« on: August 03, 2014, 11:24:13 am »
There is a transformer in my circuit which is supposed to be connected to the AC grid when needed. I don't want to leave it connected all the time in order to prevent wasting energy.
I am planning to use two MOSFETs to switch the transformer. I came to a conclusion that I need two separate isolated DC supplies to control these MOSFETs. I decided to generate clock pulse by 555 and use capacitive coupling to isolate DC component of the clock pulses, then rectify it to obtain the gate driving DC supply as seen in the schematics below.
Would this circuit work? Would the AC grid harm the low voltage side?
Do I need C4 and C7?
Note 1: The transformer will be switched once in a while at most. Therefore the switching losses can be neglected. (Isn't it?)
Note 2: I know I could do this by using MOSFET driver ICs, but they are usually more expensive.
« Last Edit: August 03, 2014, 11:25:44 am by hkBattousai »
Offline nuno
  • Country: pt
Re: Circuit idea for high side MOSFET driving
« Reply #1 on: August 03, 2014, 11:30:37 am »
How about a relay then?
« Reply #2 on: August 03, 2014, 11:32:51 am »
Simpler and easier would be to use an optically isolated triac to do the switching. Simpler, cheaper and if the load is low you can just use the triac inside the opto itself to drive the load. Otherwise you can use a low current optotriac module which both takes up a lot less board space, has one part to install and will often include zero cross switching on board for free.
« Reply #3 on: August 03, 2014, 11:37:51 am »
Using relay or optotriac are indeed simpler solutions. I thought this circuit in my mind and I couldn't anticipate it would be this complex. Maybe I should stick with a relay or opto-isolator as it is usually done.
Anyway, I just wonder would this circuit work or not. I would like to know if I correctly designed it.
Offline mij59
Online wraper
  • Country: lv
« Reply #5 on: August 03, 2014, 01:29:28 pm »
Strange and pretty expensive schematic considering all those high voltage capacitors and very dangerous. What I can see briefly trying to understand how this would work are instantly destroyed gates of the both mosfets. As well as 555 destroyed and all circuit under the mains voltage. It is almost the same as applying mains voltage between gate and source through diode and 1 uf capacitor in series.
Online wraper
  • Country: lv
« Reply #6 on: August 03, 2014, 01:35:00 pm »
Also there are schottky diode simbols on your schematic. They rarely exist rated above 100V.
Offline mij59
« Reply #7 on: August 03, 2014, 01:41:14 pm »
Maybe its should look something like this.
http://www.discovercircuits.com/PDF-FILES/FETSWITCH.pdf
« Reply #8 on: August 03, 2014, 01:49:45 pm »
This was exactly what I was trying to do. It should had been like this.
Anyway, I will use optotriac in my circuit.
Online wraper
  • Country: lv
« Reply #9 on: August 03, 2014, 01:52:02 pm »
Hard to compare them as they are completely different.
OP's schematic will work like this picture for half wave and the same for another mosfet on second half wave = BOOM.
Offline mij59
« Reply #10 on: August 03, 2014, 02:04:32 pm »
Some designs are not hindered by any knowledge.
Online wraper
  • Country: lv
« Reply #11 on: August 03, 2014, 02:24:59 pm »
need to notice that there are pitfalls when driving inductive load with such circuit.
Offline rob77
  • Country: sk
« Reply #12 on: August 03, 2014, 02:36:58 pm »
i think so.
i don't get why in the OP's schematic the 2 mosfets are "230V apart" from each other...
wiring the neutral to the transformer permanently and having the mosfet switch (in fact solid state relay) at the hot wire only would be a better and simpler solution.
btw... what's wrong with the old-school relays ? :) it's simple, isolated, safe, cheap... tons of reasons to use a simple relay ;)
Offline mij59
« Reply #13 on: August 03, 2014, 02:43:09 pm »
i think so.
In the schematic only the "switch" is drawn.
