Author Topic: Circuit protection low voltage  (Read 4476 times)
Offline davelectronicTopic starter
  • Life's too short.
« on: September 04, 2023, 09:42:10 pm »
Are there any all in one circuit protection circuits. As in over voltage and short circuit scenarios. I know there's the crowbar, but is there any other circuits that can be built in to a low voltage linear power supply. The standard 12 Volts to 13.8 Volts. Is there an IC maybe that can be added in circuit to protect the equipment connected to such a high current low voltage power supply, or is it just the crowbar circuit. Thoughts and ideas appreciated.
Offline Kim Christensen
Re: Circuit protection low voltage
« Reply #1 on: September 04, 2023, 10:22:56 pm »
Most voltage regulator ICs have built in current limiting. Some of the automotive rated regulator ICs also have overvoltage protection on the output already built in as well.
Are you adding this to an existing power supply or thinking of building one?
The following users thanked this post: davelectronic
  • Life's too short.
« Reply #2 on: September 04, 2023, 10:44:38 pm »
Building linear power supplys, with linear voltage regulator IC's and current carrying pass transistors for extra current. It's for over voltage protection, and accidental short circuit. I'm just looking for a single solution I can incorporate a protection circuit into the voltage regulator PCB board. I'm not against the crowbar, but wanted to know if there's a resettable type of protection circuit for over voltage and short circuit. Like the PSU output drops to zero, until the fault is removed.
Online langwadt
« Reply #3 on: September 04, 2023, 10:47:12 pm »
there are IC for over/reverse voltage protection and current limiting, for higher currents with external FETs
Online ledtester
« Reply #4 on: September 04, 2023, 10:53:08 pm »
For an idea of what modern efuse ICs do - here's a description of the TPS25983:
https://www.ti.com/lit/ds/symlink/tps25983.pdf
8 Detailed Description
8.1 Overview
The TPS25983 device is a smart eFuse with integrated power switch that is used to manage load voltage and load current. The device starts its operation by monitoring the IN bus. When VIN is above the Undervoltage Protection threshold (VUVP), the device samples the EN/UVLO pin. A high level on this pin enables the internal MOSFET to start conducting and allow current to flow from IN to OUT. When EN/UVLO is held low, the internal MOSFET is turned off. After a successful start-up sequence, the device now actively monitors its load current, input voltage and controls the internal FET to ensure that the user adjustable overcurrent protection threshold (ILIM) is not exceeded and overvoltage spikes are cut-off after they cross the user adjustable overvoltage lockout threshold. The device also provides fast protection against severe overcurrent during short-circuit events. This feature keeps the system safe from harmful levels of voltage and current. At the same time, a user adjustable overcurrent blanking timer allows the system to pass moderate transient peaks in the load current profile without tripping the eFuse. This feature ensures a robust protection solution against real faults which is also immune to transients, thereby ensuring maximum system uptime. The device also relies on a built-in thermal sense circuit to shut down and protect itself in case the device internal temperature (TJ) exceeds the safe operating conditions.
and:
Multiple device options exist to choose between the response to overcurrent conditions, circuit breaker, or active current limiter. The overcurrent limit threshold can be set with a single external resistor. The devices intelligently manage the overcurrent response by distinguishing between transient events and actual faults, thereby allowing the system to function uninterrupted during line and load transients without compromising on the robustness of the protection against faults. The device can be configured to stay latched off or retry automatically after a fault shutdown. The number of auto-retries as well as the retry delay are configurable with capacitors. This enables remote systems to automatically recover from temporary faults while ensuring that power supplies are not stressed indefinitely due to a persistent fault.
« Last Edit: September 04, 2023, 10:57:40 pm by ledtester »
Online David Hess
  • DavidH
« Reply #5 on: September 05, 2023, 05:04:03 am »
The crowbar circuit primarily protects the load against failure of the regulator's power pass transistor which will commonly short if it fails, connecting the higher voltage unregulated supply to the output.  It also protects against failure of the regulator's control loop allowing the output to rise.
A less common modern alternative is to add a series element like a saturated power MOSFET before the linear power pass element and control it with a comparator and latch.  There are some modern protection ASICs which work this way.
Offline PCB.Wiz
« Reply #6 on: September 05, 2023, 05:04:19 am »
These are different problems.
Normal bench PSUs are expected to tolerate shorts, and it is useful to have variable current limits too. Some have foldback current limiters.
There are IC's designed for CV/CC control like AP4310E, MP26085 etc, that have two control pathways.
If you want to protect the equipment connected to a bench PSU, that's really another module, where you would need to manually set the over-voltage trip, and set protect current trip too.
Crowbar is somewhat brutal, and assumes the bench PSU can tolerate the short.
As above there are eFuse type parts, or you could just add a LDO module of the correct V/I limits, for when you need extra protections, and anything manual can still always be set wrong.
  • Life's too short.
« Reply #7 on: September 05, 2023, 11:53:49 am »
Thank you for the IC suggestions. Do you know of any of these add on protection modules ? I'm still a relative novice, or at least I think I am. I can see a crowbar circuit with a 20 Amp fuse being quite brutal as it blew, maybe taking components with the fuse. Some of the crowbar circuits I have looked at in searches look questionable in there components choice and the configuration of the circuit. As far as crowbar circuits go, I've found a couple. But one of them has a questionable TVS diode, and the other would needa more powerful SCR thyristor. I will post these two circuits, to see what you think. I would be interested in any module add on type circuit protection also.
Offline Doctorandus_P
« Reply #8 on: September 05, 2023, 12:13:18 pm »
Over voltages and short circuits are two very different things. Simple fuses or PPTC's can help with limiting the damage for over currents. TVS diodes can help against over voltages, but they have a limited energy absorption. Same for varistors.
If you want to protect against over voltages in 12V circuits, then do a bit of research towards "Load Dump" in the automotive industry.
  • Life's too short.
« Reply #9 on: September 05, 2023, 10:22:15 pm »
Yes over current and over voltage are very different, but what I'm doing has nothing to do with automotive interests. Maybe some circuit protections are similar, probably are. I was just looking for something different with circuit protection was concerned.
Offline PCB.Wiz
« Reply #10 on: September 06, 2023, 05:09:10 am »
... I can see a crowbar circuit with a 20 Amp fuse being quite brutal as it blew, maybe taking components with the fuse. Some of the crowbar circuits I have looked at in searches look questionable in there components choice and the configuration of the circuit. As far as crowbar circuits go, I've found a couple. But one of them has a questionable TVS diode, and the other would needa more powerful SCR thyristor. I will post these two circuits, to see what you think. I would be interested in any module add on type circuit protection also.
SCR designs rely on blowing the fuse, as the SCR has no turn-off mechanism once on.
That's not really suitable for a bench supply.
There are many parts from TI that are smarter than a SCR in 2023 - they can give OV and OC limits
https://www.ti.com/power-management/power-switches/efuse-hotswap-controllers/products.html
Pick one that has the package you like, and the operating area you want.  External FET is likely best for > 10A operation. eg LM5060 ?
  • Life's too short.
« Reply #11 on: September 06, 2023, 11:44:25 am »
Thank you for the link to these devices, I had no idea they existed. Read some of the descriptions and specifications. They look perfect, might stretch my ability to select the correct the additional setting components, but if I can get past that from the data sheet, these IC's look very good.
