Author Topic: circuit safety  (Read 693 times)
Offline pete gTopic starter
circuit safety
« on: November 23, 2025, 08:59:31 pm »
hi, does anyone know a simple way to determine the value of the primary transformer fuse?
Offline moffy
Re: circuit safety
« Reply #1 on: November 23, 2025, 09:29:12 pm »
Primary wire size and core size are indicators, but require a deal of estimation. If you provide a photo along with winding diameters, its size, weight and magnetisation current someone will have a good idea. I assume though not stated that you are talking about a mains transformer.
Offline Benta
Re: circuit safety
« Reply #2 on: November 23, 2025, 09:54:32 pm »
The primary fuse is not for circuit protection, but fire protection. It's pretty uncritical.
Rule of thumb is 2 x max. primary current.
Always use slow-blow ("T") types for this kind of thing.
Re: circuit safety
« Reply #3 on: November 23, 2025, 10:15:18 pm »
so i measure the primary current, then multiply times 2. ok, thats the primary, how about the secondary? both slo blo? also is this done with no load on transformer?
« Last Edit: November 23, 2025, 10:23:48 pm by pete g »
Offline Xena E
Re: circuit safety
« Reply #4 on: November 23, 2025, 10:23:24 pm »
If feeding a rectifier/smoothing arrangement with high inrush then yes.
If you post your intended use you may get more specific answers.
Offline Benta
Re: circuit safety
« Reply #5 on: November 23, 2025, 10:25:20 pm »
You measure the primary current under full load!.
Secondary fusing is a different issue and depends on placement and circuit protection needs.
Re: circuit safety
« Reply #6 on: November 23, 2025, 11:20:09 pm »
thank you all.
