Please see the attachment.
When I give input to opto-coupler it turns on the mosfet thus actuating the relays. Even after the power opto-coupler is removed, the relays will still be powered. So only way to reset this is to release the "Emergency Button".
I can't use a microcontroller for this. What now I need to do is remove the "Emergency Button" and implement some sort of circuit which reset the circuit (Like emergency button does) automatically after a few seconds when the input to the Opto-coupler is removed.
What I thought of to be used it a 555 IC timer, but I'm not sure how can I utilize it.
Basically,
1) Opto-Coupler is powered -> relays powered
2) Opto-Coupler is not-powered -> relays still powered
3) Timer circuit cut-off power to the relays after a certain time (Opening the circuit where emergency button is and the closing it)
