Well, some ideas:
- Line codings are wildly too-heavy-weight, I'm guessing. (Good way to get high bitrates with integrated clock, but clock recovery and data separation requires a state machine.)
- You can always run a UART without an MCU. You're limited to whatever data formats it supports, and newer ones may be more complicated than is worth (e.g. you need to drive a data/address sequence to initialize control registers). Granted, you might have to go back quite far in history to find one with a minimum of registers and maximum configuration pins (e.g. did any do it where baud can be jumper selected?).
- Async with assumed timing, or something simple like Manchester where clock is integral and easily recovered, are likely options.
- Making your own async transmitter from gates isn't very difficult; a shift register clocked slow (or clock-enabled once every N clocks) and preloaded with parallel bits is all that's needed, including hard-wired '1' for start-of-frame and '0' for end. (Can even build your own XOR parity chain if you want.) Or if data are stable (or it doesn't matter when they're sampled), a mere counter+mux to sequence the bits will do. I once did this in an experimental converter controller I built in a MAX7000 CPLD, to blink out status/fault codes, but, granted a CPLD may be a bit "cheating" for here.
- PWM and PPM are always "free". They're very much the "OG" protocols, for example ADCs on the Apollo guidance computer were PPM based (>10 bits I think). You can do them in pure analog if you don't mind a bit of error (16 levels = 4 bits would require modest precision resistors, and a proper timer and comparator setup, not going to be winging it with a crude RC timing ramp and few transistors), and they're very easily received (pulse or delay counters). Probably assumes consistent timing between tx/rx, with PWM being readable without matching clock (or clock at all, as with analog filtering).
- That said, you could modify PPM into a pulse-burst coding: as long as a counter is counting up, emit a pulse AND'd with CLK. When count complete, set to zero. The burst would be variable number of pulses, and the delay between bursts fixed so that a missing-pulse detector (analog) or counter can receive it. (Complete analog rx simple enough, too: simply integrate the pulses, S&H, and reset intergrator after timeout.)
