Author Topic: Cmos switch cap circuit in Pspice  (Read 2794 times)
Offline bb551188Topic starter
« on: December 04, 2013, 07:50:26 pm »
Hi all I'm trying to implement the attached switch cap circuit.
I have the op amp par working if I just put in a AC signal, but as soon as I put in the switch cap part, I get:
ERROR(ORPSIM-15138): Convergence problem in transient analysis at Time =  42.30E-06.
         Time step =  421.0E-21, minimum allowable step size =  1.000E-18
  These voltages failed to converge:
    V(N48709)                 =     4.116V  \     4.116V
    V(N90511)                 =     2.382V  \     2.382V
    V(N51573)                 =     4.049V  \     4.049V
    V(VOUT)                   =     3.141V  \     3.141V
    V(N101867)                =     3.488V  \     3.488V
  These supply currents failed to converge:
    I(V_V22)                  =  -174.07nA  \  -173.33nA
    I(V_V29)                  =   -3.401nA  \   -2.968nA
    I(V_V30)                  =    41.97nA  \    42.52nA
    I(V_V31)                  =   -12.73pA  \   -36.38pA
  Last node voltages tried were:
 NODE   VOLTAGE     NODE   VOLTAGE     NODE   VOLTAGE     NODE   VOLTAGE
( VOUT)    3.1410  (N48709)    4.1157 (N48713)    5.0000 (N48725)    1.4192
(N48737)     .6801 (N48757)     .6130 (N48871)    1.6000 (N48889)     .7000
(N51573)    4.0489 (N60955)    2.5000 (N61751)    1.6000 (N63719)    5.0000
(N63797)    2.5003 (N90511)    2.3820 (N101549)    2.5011
(N101806)    5.0000                   (N101867)    3.4881
(N628250)     .7000                   (N637831) 465.0E-06
**** Interrupt ****
Can some one help me realize the error?
Thanks
