Author Topic: Code Composer Studio bug  (Read 3944 times)
Offline migsantiagoTopic starter
    • MigSantiago's Web Site
« on: December 26, 2010, 03:50:34 pm »
Hi
As I'm working with my launchpad, I'm using Code Composer Studio 4.2.1.00004 on Windows 7 Home Premium 64 bits.
When I try to highlight some text on the editor, the highlighting goes mad and the on-screen text gets kinda messy.
https://www.youtube.com/watch?v=2IWN_JqU6i8
I've updated the software two times and have had no luck. Any suggestions?
« Last Edit: December 26, 2010, 06:24:19 pm by migsantiago »
smindinvern
  • Guest
Re: Code Composer Studio bug
« Reply #1 on: December 26, 2010, 06:14:38 pm »
As it's a closed-source program, all you can really do is report the problem to whoever makes the software.  You could try running it in compatibility mode if you think that it's a problem with windows 7 compatibility.  Other than that, for now all you can really do is just live with the problem or use a different program.
« Reply #2 on: December 26, 2010, 06:23:18 pm »
I think it works with Eclipse, so I don't really know if it's open source or anything else.
No luck with the compatibility mode for now.  :'(
« Reply #3 on: December 27, 2010, 07:51:57 pm »
I found a workaround to this glitch... just closing the Outline window.  >:(
