Author Topic: confusing resistor  (Read 3560 times)
Offline timelessbeingTopic starter
confusing resistor
« on: July 04, 2012, 08:22:56 pm »
What would you say is the resistance of this resistor?
Offline LEECH666
Re: confusing resistor
« Reply #1 on: July 04, 2012, 08:26:11 pm »
Could be an inductor as well.
http://www.elexp.com/t_induct.htm
The color codes read as:
Green = 5
Blue = 6
Gold = x0.1 (Multiplicator)
Silver = 10% (Tolerance)
So it might either be a 5.6 Ohm 10% resitor or a 5.6 µH 10% inductor.
My guess would be inductor tho, maybe someone else can verify this.
Cheers,
Florian
« Last Edit: July 04, 2012, 08:30:08 pm by LEECH666 »
« Reply #2 on: July 04, 2012, 08:29:10 pm »
I hadn't thought of that. I do measure a resistance across it, though.
Online madires
  • A qualified hobbyist ;)
« Reply #3 on: July 04, 2012, 08:37:38 pm »
Hi!
You're right! It's an inductor.
Cheers
 madires
« Reply #4 on: July 04, 2012, 08:41:53 pm »
More likely to be an inductor, with the green body coat. It will have some DC resistance as well, you would have to connect it up to something other than a simple resistance check to be sure.
Break it apart and you will see the wire. Trying a magnet will not be definitive, as most resistor end caps are steel, while inductors use a ferrite core as well.
« Reply #5 on: July 04, 2012, 10:03:01 pm »
You're right! I put a few volts across it, and it picked up little bits of metal. I was confused because it measured 0.56 ohms which is so similar to 5.6.  No wonder my circuits were acting strange!  So how are you supposed to tell them apart? These components come in a whole rainbow of colours!
« Last Edit: July 04, 2012, 10:04:32 pm by timelessbeing »
Offline IanB
« Reply #6 on: July 04, 2012, 10:10:07 pm »
Inductors usually have a brightly coloured coating and look fatter and more bulbous, while resistors usually come in dull colours and look thinner and more rectangular.
