EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
connecting RF and biasing PCB's together X-microwave
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: connecting RF and biasing PCB's together X-microwave (Read 550 times)
john23
Frequent Contributor
Country:
on:
September 14, 2025, 11:31:27 am »
Hello,I have a question regarding a variable attenuator .
Generally we plug the biasing network to the RF component using spring pins.
As you can see in the photo below there is no sping pin present. so how do i need to connect the two PCB's threw the proto plate?
Thanks.
RF component:
https://catalog.quanticxmw.com/item/attenuators/voltage-variable-attenuators/xm-b6h5-0404d
Biasing network:
https://catalog.quanticxmw.com/item/bias-and-control/voltage-regulators/xm-b1x6-0404d
Logged
yngndrw
Regular Contributor
Country:
Re: connecting RF and biasing PCB's together X-microwave
Reply #1 on:
October 28, 2025, 06:19:36 pm »
They have both a version with and without spring pins:
https://catalog.quanticxmw.com/item/bias-and-control/voltage-regulators/xm-b1x6-0404d-sp
The getting started guide does suggest that you can also use soldered wire instead:
https://quanticxmw.com/wp-content/uploads/Quantic-XMW-Getting-Started-Guide-v3.pdf
I couldn't seem to find the spring pins on their site, but it might be worth asking - I'm sure they'd sell them to you separately.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
