OK - let's get a clearer spec / definition of the problem.
Trickle feed is not doing it for me
You are expecting - - 3 x 7-seg displays (8 pins with muxing... more detail later)
- 12 banana sockets at LOCAL end.
- 12 banana sockets at REMOTE end.
- 6 (more/less?) leads between local & remote.
Possibly cross-wired in no particular order.
No connection between - other than the banana leads - Smallest / cheapest solution possible
GOAL: You want to identify
which LOCAL banana socket is connected to which REMOTE banana socket.
(Some may not be connected at all)
(Are 'shorts allowed? One local to two or more remotes? Vice-versa?)
Is that correct?
Does this gadget serve any other purpose than to check if leads are present and connected?
If yes - that will add a burden of not interfering with other signal traffic... harder!
There may be several strategies, scanning of the bananas is one - there may be others.
If this is correct, then I'll sketch out a first thought. You will have to do some coding!
Will try to avoid a micro at remote end - but will require at least two leads in place.
This sounds like a cable tester (!)
