Author Topic: Connector Advice  (Read 3217 times)
Offline gilbenlTopic starter
Connector Advice
« on: January 05, 2016, 08:51:50 pm »
Working on a simple DAQ for some medical research that I'm doing. Need to connect some micro thermistors to my leads and then the leads to the DAQ. I need to be able to detach the sensor from the lead and the lead from the DAQ. Was going to do BNC, but that appears as though it will cost me ~$5/connection (2 connections per sensor, 4 sensors=$40 just in connectors).
Anyone have some tips on cheap, rugged connectors suitable for in vivo research? No need to be waterproof but should not disconnect easily.
Or...cheap BNCs?
What doesn't kill you, probably hurts a lot.
Offline Vgkid
Re: Connector Advice
« Reply #1 on: January 05, 2016, 09:40:33 pm »
Can you have many sensors going to 1 connector?
Db-9, or its family.
Offline _Andrew_
« Reply #2 on: January 05, 2016, 10:06:53 pm »
If it is just two pin locking connectors you need try looking up TE Connectivity Mini-Universal MATE-N-LOK
Sockets, plugs and the pins to go in them are sold separately but if you can find someone in your region that will sell small quantities then these could be significantly less costly.
http://www.te.com/usa-en/product-172165-1.html
http://www.te.com/usa-en/product-172343-1.html
« Reply #3 on: January 06, 2016, 04:37:49 am »
This is a reasonable choice. Wrap them in cell-o-wrap during the experiments. However, they're not very skookum to quote some other guy.
DB-9esque solutions not appropriate in this application, although bonus points for efficiency :-+. Is there a locking form of RCA? Small is good, by the way. Using 22Ga shielded bipolar leads.
Offline Tomorokoshi
« Reply #4 on: January 06, 2016, 06:06:43 am »
I like these:
https://www.digikey.com/product-detail/en/1803426/277-1221-ND/260589
https://www.digikey.com/product-detail/en/1827127/277-1191-ND/260559
Four sets would run about $12 total.
They are robust, and the friction connection holds well enough. Screw terminals make it easy to adapt. Saves a lot of labor over crimping pins.
There are other sizes in both pitch and number of circuits.
