Author Topic: Connector Help [Solved]  (Read 4125 times)
Offline alvaropTopic starter
    • alvarop.com
« on: June 22, 2011, 09:57:43 am »
I've been working with this board I'm trying to figure out what connectors it is using.
Any tips would be appreciated, I'm not even sure what to search for.
Thanks!
« Last Edit: June 22, 2011, 10:16:00 am by alvarop »
Offline david77
Re: Connector Help
« Reply #1 on: June 22, 2011, 10:02:43 am »
On the left hand side of the socket on the 2nd photo there's a marking. MX J (maybe L)?
Take a good magnifying glass and look for other markings.
    • alvarop.com
Re: Connector Help
« Reply #2 on: June 22, 2011, 10:15:16 am »
I didn't even see that!
A quick google search led me to the right result.
They are Molex connectors #0541670208 and #0537480208 in case anyone is interested.
Thanks for the help!
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: Connector Help [Solved]
« Reply #3 on: June 22, 2011, 10:59:12 am »
have you traced the connectors where they are going? that can give you a clue like where's the power and ground pins, i/o signal etc. so you have better hint when you've found reference in the net.
    • alvarop.com
« Reply #4 on: June 22, 2011, 12:21:00 pm »
That will be the next step. I wanted to make sure we could get the connectors before doing any further work.
  • Country: my
« Reply #5 on: June 22, 2011, 12:34:09 pm »
sorry i meant the socket, not connector. a simple continuity check with dmm and needle sharp probe on the "socket" and circuit is whats needed i think?
