Author Topic: connector type?  (Read 1827 times)
Offline bonesTopic starter
connector type?
« on: June 14, 2016, 09:39:40 pm »
I need some of these connectors... only I can't figure out what to order.  :-\
Could someone ID them for me, please?
Pitch is 0.1" or maybe 2.5mm.
Offline lincoln
Re: connector type?
« Reply #1 on: June 14, 2016, 09:47:48 pm »
Look for JST connector
Offline Yansi
Re: connector type?
« Reply #2 on: June 14, 2016, 10:04:46 pm »
JST is only the name of manufacturer.  If it is .1" pitch, than it very likely might be JST-XH type.
Offline TimFox
Re: connector type?
« Reply #3 on: June 14, 2016, 10:12:16 pm »
To determine if the pitch is 0.10 inch or 2.5 mm, measure the total span of a large number of pins.
Re: connector type?
« Reply #4 on: June 14, 2016, 10:23:53 pm »
Thank you, all.
Yansi, I think JST-XH looks right. Much appreciated. I had already looked at some other JST series.
TimFox, most I had was 6 pins...  I figured 0.25mm was probably inside my margin of error. :-)
Offline Yansi
Re: connector type?
« Reply #5 on: June 14, 2016, 10:31:36 pm »
Well silly me... The JST-XH series are 2.50000mm metric connectors.  Haven't done anything with them for a while, sorry.
http://www.jst-belgium.be/downloads/series/eXH_1.pdf
« Last Edit: June 14, 2016, 10:37:03 pm by Yansi »
The following users thanked this post: bones
Re: connector type?
« Reply #6 on: June 14, 2016, 10:59:29 pm »
Yep, but pretty sure they're the right ones.
