I have purchased an OCXO. The data sheet states that the unit operates on 5V and draws a maximum of 600mA, upon start up. The voltage for the frequency adjustment is +/-2V. However, the current draw for the frequency adjustment voltage is not stated in the data sheet. Should I assume this draw to be the same as the working voltage, as much as 600mA on start up? Thank you for your help.
