With a physically small trimmer, extra inductance probably isn't an issue. However for a BLDC controller are you going to use 6 trimmers and match all of them in value?
Really, you would use one value of Rg and then spend possibly an hour taking measurements (ringing, efficiency, etc.), and then choose another value of Rg and redo the measurements. Maybe a third value. So it would be simplest by far to just desolder and resolder different values of fixed resistors, this is what I always do. Added benefit is you can commit to as final as possible PCB layout from the start and don't need to waste board area for those trimmers.
You can really ballpark-calculate the range of Rg you want to work with (e.g., simple equation matching Qg(tot) = time * gate current), and then fine-tune with measurement. For example, if calculation says 3 ohms, you may want to test with 0, 2.2 and 4.7 ohms.
