Author Topic: converting UKV to FM.  (Read 1819 times)
Offline Deactivated-1Topic starter
« on: February 19, 2020, 10:14:25 pm »
UKV which is a 65.8–74 MHz FM band, also called OIRT apparently according to Wikipedia.
so I want to modify this UKV modulator? converter? I think box to pickup higher frequency bands, the whole modern FM band would be great but to be exact I want 94MHz - 103MHz to be picked up
 if it's still not possible simply to get so wide range then either 98MHz - 103Mhz or even 104 Mhz to 106Mhz will probably be enough.
here's the schematic for the modulator thingy from a rigonda 102.
[ Attachment Invalid Or Does Not Exist ]
unfortunately, it doesn't have the inductor values specified, I'll try to find the specs and post them here if I can.
Offline orbanp
Re: converting UKV to FM.
« Reply #1 on: February 21, 2020, 01:20:40 pm »
What is the model number of the radio? (It sounds like it might not be the Rigonda-102.)
Rigonda has different tube radio models where the FM tuner does vary a little bit from one another (like L4 is a tapped coil or not).
This is a slug tuned FM module. In my experience (I converted one similar FM tuner to the CCIR band) it involves making new coils, just changing capacitances did not work. Lots of experimentation, as well as simulations, so you better have some test instruments as well. The other problem is, as you identified, that the coverage of the CCIR band is a lot wider than the old OIRT band. I did not achieve full coverage.
The other tube-based FM module I converted was capacitor tuned. It also needed new coils as well as a number of capacitor changes. There I achieved full coverage (88MHz - 108MHz).
Regards, Peter
« Last Edit: February 21, 2020, 01:41:16 pm by orbanp »
