after abusing the AI with a metre stick a few times, this is what we have;
## Forum Draft Teaser (For your EEVblog Thread)
If you want your friends to appreciate the theatricality, you can intro your schematic text with a caption like this:
Gentlemen, behold... my latest creation. I call it... "The Light Activator."
No, it doesn't involve sharks with frickin' laser beams attached to their heads, but it
does combine raw 12V automotive power with the absolute perfection of 4000-series CMOS
logic.
I demand the community scrutinize this blueprint before I deploy it to the four corners
of my vehicle for a total cost of... ONE MILLION DOLLARS! (Or, you know, about
forty bucks on DigiKey).
Here is a clean, well-spaced plain-text breakdown of your complete project. It is perfectly formatted to copy-paste straight into an EEVblog forum post, allowing the community to review the hardware architecture, logic math, and component selection.
1. LOGICAL EXPRESSION & TRUTH TABLE
This circuit solves the conditional transmission gate problem where S (Control) physically gates the wire routing T (Signal), while integrating P (Primary) as an independent override line.Mathematical Expression:OUTPUT = NOT( NOT(P AND NOT(S)) AND NOT(T AND S) )Functional Equivalence (via De Morgan's Law):OUTPUT = (P AND NOT S) OR (T AND S)The 3-Input Integrated Truth Table:
P │ T │ S │ Transmission Line State │ OUTPUT
0 │ 0 │ 0 │ T is blocked (0) │ 0
0 │ 0 │ 1 │ T passes through (0) │ 0
0 │ 1 │ 0 │ T is blocked (0) │ 0
0 │ 1 │ 1 │ T passes through (1) │ 1
1 │ 0 │ 0 │ T is blocked (0) │ 1
1 │ 0 │ 1 │ T passes through (0) │ 0
1 │ 1 │ 0 │ T is blocked (0) │ 1
1 │ 1 │ 1 │ T passes through (1) │ 1
2. ASCII LOGIC DIAGRAM (NAND-ONLY IMPLEMENTATION)To ensure high-reliability native 12V operation under automotive conditions, the layout is broken down into four standard 2-input NAND gates using a single CD4011BE CMOS chip.
UPDATED STANDALONE NODE ARCHITECTURE WITH PULSE FILTER
P ────[1kΩ]───┬───────────────────────────────────────────────┐
[Zener] │
[10kΩ] ╔═════════════╗
│ ║ NAND 2 ║───┐
GND ┌────────────────────>║ (Gate 2) ║ │
T ────[1kΩ]───┬──────────────────────┴───────┐ │
[Zener] ╔═════════════╗ ▼
│ ║ NAND 3 ║──┐ ╔═════════════╗
[10kΩ] ║ (Gate 3) ║ │ ║ NAND 4 ║─── OUTPUT
│ ╚═════════════╝ │ ║(Final Mixer)║ (Pin 11)
GND ▲ │ ║ (Gate 4) ║
[Internal S] │
[1N4148 Diode]
│ 10µF Cap │
GND
3. AUTOMOTIVE HIGH-CURRENT OUTPUT BLOCKThe output pin of NAND 4 safely drives an N-Channel Power MOSFET to control the high-current light loop without mechanical wear points.
AUTOMOTIVE HIGH-CURRENT LOGIC & SWITCHING SIGNAL FLOW DIAGRAM
[RAW VEHICLE SIGNAL INPUTS] [INPUT CONDITIONING STAGE] [CORE CMOS NAND LOGIC MATRIX]
(From Switch P) ───┬────────────────────► [1kΩ Resistor] ───┬───► [Conditioned P] ────► Pin 6 (NAND 2 Input B) ──┐
(Powers Light) [Zener] ╔═════════════╗
│ │ ║ NAND 2 ║───┐
│ [10kΩ] ║ (Gate 2) ║ │
╔═════════════════════╗ GND │ │
║ LIGHT FIXTURE ║ ▼ │
║ (Gets Power from P) ║ Pin 12 (NAND 4) │
[LIGHT NEGATIVE RETURN] │ │
│ (Enters Plug Pin 5) │ │
[M_Dr] (Hole C28) │ │
├──────────────────────► [1kΩ Resistor] ───┬───► [Conditioned T] ────► Pin 9 (NAND 3 Input A) ───┤ │
│ [Zener] ▼ ▼
│ [10kΩ] ║ NAND 3 ║║ NAND 4 ║──► FINAL OUT
│ │ ║ (Gate 3) ║║ (Final Mixer) (Pin 11)
│ GND ╚═════════════╝╚═════════════╝
(Pulsing Turn Stalk) │ │
[ HARNESS WIRE T ] ───────────────────────────────────────────┴───► [1N4148 Diode] ──┐ │ │
[10µF Cap] ──┬── Pin 10 (NAND 3) ──────┘ │
GND └── Pin 1 (NAND 1) ────────────────────┘
(Internal Detected S Line)
[HIGH-CURRENT LOW-SIDE SOLID-STATE OUTPUT SWITCHING STAGE]
[ FINAL LOGIC OUTPUT ] ──► [ Hole A11 ] ──► [ 1kΩ Resistor [R4] ] ──► [ Hole A28 ] ──► ╔═══════════╗
(From CD4011BE Pin 11) ║ GATE ║ (Hole B28)
║ IRFZ44N ║
[VISHAY 1N4007] ║ MOSFET ║
┌───[FLYBACK DIO]──────────────────────>║ ║
[ CONTINUOUS +12V RAIL ] ──(Cathode Stripe)────┘ │
(Powers CD4011BE Pin 14) ▼
[M_Sr] (Hole A29)
▼ (Enters Plug Pin 2)
[ MASTER CHASSIS GROUND ]
4. DIGI-KEY SHOPPING CART (SCALED FOR 4 MODULES)To ensure this survives vehicular vibrations, the build drops plastic solderless breadboards entirely. It switches to a distributed multi-box architecture consisting of four independent, shielded modules located at each corner of the car.The list leverages TE Connectivity for premium passive components alongside AEC-Q101 equivalent silicon leaders (Texas Instruments, Infineon, onsemi, and Vishay).
- Hammond Mfg 1551SNAPBK Snap-Together Box
- Quantity: 4
- Part Number: 1551SNAP3BK
- Link: digikey.ca
- Purpose: Toolless ABS enclosures protecting each independent corner circuit module from road debris.
- Adafruit 1608 Perma-Proto Breadboard PCB
- Quantity: 4
- Part Number: 1608
- Link: digikey.ca
- Purpose: Gold-plated, through-hole proto-boards that fit inside the enclosure and won't drop components under vibration.
- Texas Instruments CD4011BE Quad NAND IC
- Quantity: 4
- Part Number: CD4011BE
- Link: digikey.ca
- Purpose: CMOS core logic chip operating natively at 12V to handle vehicle battery charging voltage profiles.
- Assmann WSW 14-Pin IC Protective DIP Socket
- Quantity: 4
- Part Number: A 14-LC-TR
- Link: digikey.ca
- Purpose: Isolates the CD4011BE silicon pins from high thermal stresses during hand soldering.
- TE Connectivity CFR25J1K0 1 kΩ Carbon-Film Resistors
- Quantity: 12 (3 per corner board)
- Part Number: CFR25J1K0
- Link: digikey.ca
- Purpose: Premium TE inline current-limiting buffer resistors filtering raw line transients on inputs P, T, and S.
- TE Connectivity ROX1SJ10K 10 kΩ Flameproof Resistors
- Part Number: ROX1SJ10K
- Link: digikey.ca
- Purpose: Heavy-duty 1-Watt pull-down resistors to enforce clean low states when inputs drop out.
- onsemi 1N4742A 12V 1W Zener Clamping Diodes
- Part Number: 1N4742A
- Link: digikey.ca
- Purpose: Clips high-voltage surges over 12V safely down to ground right at the input boundary.
- Infineon IRFZ44NPBF Power MOSFET
- Quantity: 4 (1 per corner board)
- Part Number: IRFZ44NPBF
- Link: digikey.ca
- Purpose: Solid-state N-Channel switch to drive the heavy lamp load quietly without mechanical relays.
- Vishay 1N4007 High-Voltage Flyback Diodes
- Part Number: 1N4007-E3/54
- Link: digikey.ca
- Purpose: Suppresses inductive kickbacks from long vehicle wire bundles when switching off the lamps.
To lean into the Austin Powers theme for your EEVblog post, you can pitch the project with a heavy dose of dramatic flair. Presenting a relatively straightforward 12V lighting controller as a "highly classified, over-engineered vehicular command module" is exactly the kind of humor that resonates well with engineering forums.
Here is the exact pin-to-pin track layout for the CD4011BE, written out as a blueprint ready to show your peers.
THE DR. EVIL "MASTER PLAN" PINOUT MAP (CD4011BE)A standard CD4011BE contains four independent 2-input NAND gates inside a single 14-pin package. To execute the logic seamlessly, wire the pins on your Adafruit Perma-Proto board using this blueprint:
- Power & Ground Rails
- Pin 14 (VDD): Connect directly to your clean, conditioned +12V Power Bus.
- Pin 7 (VSS/GND): Connect directly to your Chassis Ground Bus.
- Gate 1: The "S Inverter" (~S)
- Pin 1 (Input 1A): Connect to conditioned Input S.
- Pin 2 (Input 1B): Connect directly to Pin 1 (tying inputs together creates a NOT gate).
- Pin 3 (Output 1): Outputs NOT S. Run a jumper wire from here to Pin 5.
- Gate 2: The "Primary Override Selector" [P AND ~S]
- Pin 5 (Input 2A): Connect to Pin 3 (receiving the NOT S signal).
- Pin 6 (Input 2B): Connect to conditioned Input P.
- Pin 4 (Output 2): Outputs NAND(P, NOT S). Run a jumper wire from here to Pin 12.
- Gate 3: The "Transmission Pass-Through" [T AND S]
- Pin 8 (Output 3): Outputs NAND(T, S). Run a jumper wire from here to Pin 13.
- Pin 9 (Input 3A): Connect to conditioned Input T.
- Pin 10 (Input 3B): Connect to conditioned Input S.
- Gate 4: The "Final Mixer" (The Output Stage)
- Pin 12 (Input 4A): Connect to Pin 4 (Output 2).
- Pin 13 (Input 4B): Connect to Pin 8 (Output 3).
- Pin 11 (Output 4): This is your FINAL LOGIC OUTPUT. Connect this directly to the Gate of your IRFZ44N MOSFET through a 1kΩ resistor.
If you want to take the forum review further, I can help you draft the troubleshooting guide for your friends to check, or look up AEC-Q101 automotive enclosure alternatives if you want to ensure the boxes are fully dustproof. Which would you prefer?
---- i have to check all of this, but i wanted to share what i got
