how do you know the CSA of braid to choose the right connector?
Can you just roll it up and measure it like a wire and get good reliable results going by a AWG table? I.e. cut off 2cm, cut it length wise and then roll it up tight and measure with caliper. Then use 22-12 AWG barrel crimps. I mean even with stranded wire, you are supposed to measure only 1 strand and then use math to get the true copper CSA. Granted with yellow blue red crimps, the range is pretty big.
Since its woven and not parallel or just lightly twisted I was not sure the crimp does a good job or if its too puffy or something. I don't have one to measure but I am trying to decide something in the design stage right now for ordering parts. I am worried it will not be reliable or stable.
I thought maybe... its better to fill the braid with stripped wire, then crimp it to that wire gauge + 1 or something? So you are crimping a fairly solid core. I assume you should not try this with single strand wire and you should choose multi strand wire for filling the braid at the termination, if you try it this way. What strand count is good, higher = better, since it is similar to the braid itself (very fine wires), or does that just cause more trouble?
I assume the only connector that makes sense with a braid is a big lug, putting it on a fast-on seems a little silly.
Should it maybe just be clamped down in some kind of nickel strip sandwich which is then screwed to something (custom part)?
