Author Topic: Critique my LED PWMer  (Read 20514 times)
Offline magic
Re: Critique my LED PWMer
« Reply #25 on: October 20, 2021, 06:35:35 am »
Quite the opposite: R9 provides path for ESD to reach Q8 gate when Q7 is off and break down the gate insulation. Such resistor should be connected straight to the source.
Offline Siwastaja
« Reply #26 on: October 20, 2021, 09:53:14 am »
Seeing you seem to worry about the inaccuracy in LED current due to nonlinearity of PWM, do you realize LED Vf varies all over the place with temperature etc., and your 5V supply varies, too, so you never get regulated, accurate current with simple series resistor driver anyway. If you need accurate LED current, you need to measure it and feedback. If you need accurate output, you need to sense the light and feedback on that.
Offline robzyTopic starter
« Reply #27 on: October 20, 2021, 11:44:28 am »
Oh! That's a good point! I was aware that ESD on the gate was an issue, it didn't really click with me that ESD's impact on Vgs could be an issue. In this case my chosen MOSFETs have inbuilt zener(?) diodes between gate and source, would that've saved them?
Either way I'll modify my design to put the fuse before the current limiting circuitry.
To clarify my previous point - I don't need accurate LED current, but I want to know the relative change in power from nominal 1uS pulses to 2uS pulses. And its easiest to do this if the actual pulse length is close to the nominal pulse length (i.e. not eaten up by MOSFET switching time).
Offline StillTrying
  • Country: Broken Britain
« Reply #28 on: October 20, 2021, 01:40:11 pm »
Why don't you view the 1 & 2us light pulses with a photodiode, a couple of us have done it here. :)
https://www.eevblog.com/forum/chat/20w-halogen-bulb-viewed-by-a-photodiode/msg2411274/#msg2411274
With 1A through the LED you wouldn't need any photodiode amp.
« Reply #29 on: October 20, 2021, 11:35:19 pm »
Oh that's cool! Thanks for the link!
I don't have any measurement equiptment with the required bandwidth, though, and even if I did I'd still like to invest engineering effort up-front to make sure the circuit switches fast enough that 1uS pulses are approx half the length of 2uS pulses.
