Kenwood-Trio oscilloscope tube, fitted to CS-2100/2070 models (tube type 150ATM31A)
Early searches don't reveal any info about driving it though. Can anyone suggest where I might find a datasheet? Or even schematics for the scope it's out of?
Hah! I have a Trio CS-2100 scope. Never was able to find a paper original or PDF manual. I ended up buying a photocopy which leaves a lot to be desired. It seems the original is mostly 2 and 3 fold foldout pages, printed double sided, with color board layouts. So the A4 sheets sticky-taped together copy is horrible. Also whoever did it then put it in a plastic cover ringbinder, so the sheets near the front and back have that effect where the pvc plasticiser has made the toner stick the sheets together, and transfer between the pages. Urgh. It's too nasty to consider doing a full scan for online archiving, unfortunately. If anyone knows of an original copy, please let me know.
It doesn't seem to include a detailed spec set for the CRT anywhere. A couple of relevant sheets below. I could scan the driver board schematics too if you like.
Hey, if you ever want to sell that tube, I'd like to buy it as a spare. Also did you mistype 150ATM31A when it's actually 150KTM31A ?
Or maybe it's a slight variant?
