What does positive saturation voltage specification mean?
I see a curve showing me that under a heavy load and higher temperature the saturation voltage for a particular amplifier is higher.
If I understand this correctly this amplifier will be able to use a greater voltage if it is running hot (120C) and under a heavy load then it does running under a light load at a reasonable temperature.
wtf? I figure it would be the inverse. Why does its saturation voltage increase as the stress it is placed under increases?
